Acceleration Problems... Help Please
  • Bowlerwell
    • Sep 2005
    • 1052
    Hey Folks.
    I was driving home this evening and discovered a problem.
    I put my foot to the floor in 6th, and it started doing this jerky accelerating thing...
    I tried in other gears and it was the same.
    It seemed to get worse, to the point that I couldn't pull away from traffic lights too fast, or it's start jerking (in a periodic fashion, quite violently)...
    Any ideas?
    Thanks!
    JB
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
  • BRY
    • 3755
    search for overboost
    • Bowlerwell
      • Sep 2005
      • 1052
      Thanks BRY.
      I'll have a search. But didn't I read somewhere that overboost only occurs in 5th and 6th gears?
      John Bowlerwell
      Electronic Engineer
      Present:
      Previous:
      • urquattro-island
        • Mar 2006
        • 1915
        • Home: Norway Current: Iceland
        no trust me, has happend to me to in 4gear and 3...
        japanischer industriabfall nein danke!!
        www.rackeltrim.se Icelandic Division
        • Bowlerwell
          • Sep 2005
          • 1052
          ok... So previous posts seem to say:
          1: check for boost leaks
          2: clean the MAF sensor
          3: replace the WGFV
          4: check wastegete diaphragm
          Is this the advisable order to carry things out?
          Can I please have instructions on how to carry these tasks out?
          Thanks folks!!
          JB
          John Bowlerwell
          Electronic Engineer
          Present:
          Previous:
          • BRY
            • 3755
            Overboost protection is what I should have told you to search for, sorry.
            You will have a loose pipe to your wastegate or your wastegate diaphram will be wasted.
            A pressure check on the system will find this straight away.
            Search for pressure check / testing
            • Bowlerwell
              • Sep 2005
              • 1052
              Thanks BRY!
              Will search.
              Will this problem show itself in the fault codes in VAG COM ?
              John Bowlerwell
              Electronic Engineer
              Present:
              Previous:
              • Bowlerwell
                • Sep 2005
                • 1052
                ok, so there seems to be loads of threads talking about pressure testing, but I can't find any that actually tell me how to do it. Can anyone point me in the right direction?
                Pictures would be good too...!
                Thanks,
                JohnB
                John Bowlerwell
                Electronic Engineer
                Present:
                Previous:
                • SR71
                  • Apr 2004
                  • 330
                  You might just have a dirty MAF connection.
                  Try disconnecting the MAF and cleaning the contacts.
                  My $0.02 to see if an easy solution presents itself.
                  00 Audi B5 S4 MRC550
                  08 RRS TDV6 HSE
                  03 Kawasaki B2 ZX12R 1287cc
                  • urquattro-island
                    • Mar 2006
                    • 1915
                    check your relief valve too, I changed mine and it helped..
                    • pjeast73
                      • 144
                      sounds similar to a problem I had - cured by cleaning the MAF. Worth a try - search the form for 'MAF cleaning' - there's a post with a walkthrough with pictures. HTH
                      • Bowlerwell
                        • Sep 2005
                        • 1052
                        I found the MAF Cleaning thread. Wonderful description with good pics.
                        What i'm not sure about is the pressure test. I'm not sure of the procedure.
                        Is it:
                        disconnect hose from MAF, bung the hose but attach the air compressor on this end...?
                        Thanks,
                        JB
                        John Bowlerwell
                        Electronic Engineer
                        Present:
                        Previous:
                        • Bowlerwell
                          • Sep 2005
                          • 1052
                          Why can't I upload pics? Just sends me to a blank screen and says 'done' in the bottom left corner.
                          I've taken the MAF out, and it looks pretty sparkley clean. Don't want to waste my IPA, so would like oppinions as to whether it's actually clean, or just looks clean to me...
                          John Bowlerwell
                          Electronic Engineer
                          Present:
                          Previous:
                          • Bowlerwell
                            • Sep 2005
                            • 1052
                            Here goes.
                            Does this part really require cleaning?
                            Thanks...
                            John Bowlerwell
                            Electronic Engineer
                            Present:
                            Previous:
                            • BRY
                              • 3755
                              I think it looks quite clean, it wouldn't hurt though.
