RS2 cams have no gear to drive the distributer so you would have use 3B or 7A cams. Or convert to ABY/ADU ignition. Other than that it should work fine.
Also the RS2 cam pully is a different size so you need to change that out for a 3B/ABY unit.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
