Getting there
  • Azman
    • Sep 2005
    • 3205
    Getting there
    Right guys.
    Slowly getting there,
    I have just got my hands on a recirculating dump vavle and have a wastegate frequency valve on the way some time soon, New Vaccum piping on order and hopefully a new set of intake pipes in alloy with SFS joiners to tidy the whole intake side up a bit.
    One thing though.
    How do I plumb in the FV. Is it a pipe from the top of the wastgate to the frequency valve only or is there more plumbing involved.
    I have 4m of vaccum tubing on order so I should have enough for a good bit of plumbing to be done.
    Aaron
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • AndyP
    • 6049
    Tale plenty of pics of the old one before you remove it, them mark up the hoses one at a time as you remove them, then simply replace with the new valve.
    If you get stuck search for WGFV on here, I'm sure there is a picture somewhere telling you which pipe goes where.
    • Azman
      • Sep 2005
      • 3205
      Andy - I don't have a WGFV on at the mo. So I can't mark anything up to replace it. AH well. CAn someone post a piccie or a descripton of what links to what.
      Aaron
      Dark Grey Avant
      RS2 FARB
      • Azman
        • Sep 2005
        • 3205
        Just been to see the guy about the intake piping. He is cool and seems to know what he is on about judging from what he had on show and also the fact that he builds and deals with historic rally and kit cars.
        Good price too. He did look under the bonnet and start to panic abit at the amount of room there is to play with so we are coming up with something to give a touch more room.
        A few questions though guys -
        Is the MAF one way flow?
        Just to check - does the recurculating dump valve dump before or after the turbo?
        Cheers guys. Will post pics by the end of next week hopefully with it all done.
        Dark Grey Avant
        RS2 FARB
        • Jon441cc
          • Dec 2005
          • 2061
          MAF sensor is directional it has an arrow on it to show air flow, the recurculating valve dumps air back in before the turbo into the MAF to turbo hose how about taking the air filter into the cavity of the wing?
          • Azman
            • Sep 2005
            • 3205
            Just been thinking that but then its the cold air feed that would be a bit of a problem!
            Unless you have got any ideas as to where it should go/come from
            Dark Grey Avant
            RS2 FARB
            • Jon441cc
              • Dec 2005
              • 2061
              The cold air feed could come from the top of the oil cooler shrouding.
              Doug did something like this for his cold air feed
              I will be doing something like this in the future.
              • Azman
                • Sep 2005
                • 3205
                Problem with that is I don't have an oil cooler feeder. I just have an oil cooler sitting in the air as I converted to the 3B. Right. What we have come up with is to take the inlet pipe from the Maf to the turbo having the Maf sit behind the headlight and a short 90deg of to the filter which will give a whole lot more room. It's just sqeezing the breather inlet and the recirc inlet all on the same bit of pipe. Hey ho I'm sure we will find a way.
                Keep you posted!
                Dark Grey Avant
                RS2 FARB
                • jogi730
                  • 2335
                  There has already been talk about this on another thread..... get rid of the foglights which are not of much use really and replace with an intake + ducting available from most car accessories shops (def DemonTweeks and the like). May have to trim a bit but will do the job nicely.
                  I did this to feed my oil cooler and it helped cooling immensely.
                  Hope this helps.
                  Chris
                  Audi 90 quattro (Typ 85)
                  20v turbo conversion
                  • WabTheKing
                    • May 2004
                    • 2567
                    arron, all the piping for a recirc is already there as i ran one before changing to atmosphric
                    • Azman
                      • Sep 2005
                      • 3205
                      Yep Sure is Will but I want to create a bit more room if possible on that side so I can move bits away from the hot side and get some heat shielding in there. Gonna have to create a bracket for the oil cooler too. Still got lots to do and sort on this car and the projecty one arriving soon.
                      I must be mad
                      Dark Grey Avant
                      RS2 FARB
