Top end rattle
  • phil2.016v
    • Mar 2006
    • 300
    Just had the car back after having the geabox reconed, and the top end still rattles even with the thicker oil in it. How do you get at the ballvalve, is it a head off job?
    If the valve is playing up this could cause the intermittent rattle that i'm getting.
    If this works it could save people a lot of money as the previous owner of mine spent about 900 quid trying to stop this rattle!!!
    Audi 80 2.0
    E21 BMW 316
    Ibiza Cupra Sport
    Mk3 Golf GTI colour Concept in black!
    Mk3 Golf GTI
    VW Caddy van with my gottis on it
    • phil2.016v
      • Mar 2006
      • 300
      Does anyone know how to get the ballvalve out?
      Audi 80 2.0
      E21 BMW 316
      Ibiza Cupra Sport
      Mk3 Golf GTI
      • s2dude
        • Nov 2005
        • 1631
        Quoted from the thread link
        It is located behind one of the two oilpressure switches. If you remove the switch you will see a thread adapter. Remove this and use a flashlight into the canal and you can see the valve. The valve is threaded and you have to use a torx? (12 "tacs") key to take it out. The valve is ~25mm long and ~10mm in diameter.
        It's an inexpensive part and should be changed if you take the engine apart.
        Item 25 on the picture
        • phil2.016v
          • Mar 2006
          • 300
          Cheers for that, I've only just read it!! I'll look a bit harder next time.
          Audi 80 2.0
          E21 BMW 316
          Ibiza Cupra Sport
          Mk3 Golf GTI
          • phil2.016v
            • Mar 2006
            • 300
            #20
            I thought i'd finish this one with some good news
            I sent the Avant over to my mates Garage to have the big ends and mains checked as part of the ongoing top end investigation. They removed the sump and inspected the bearings all of which were perfect.
            He then checked the oil pick-up onlt to find that it was blocked almost solid Amongst the contents was a ball of masking tape How the hell did that get there???
            Anyway it's all sorted now and sounds fantastic at last.
            Audi 80 2.0
            E21 BMW 316
            Ibiza Cupra Sport
            Mk3 Golf GTI
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              #21
              Good News
              Having never noticed this thread before, I just read it through and noticed your ealier question on boost pressure. What boost are you seeing as 7 - 10 PSI is way too low.
              Cheers n
              Si
              Subtle mods here and there
              2011 A5 3.0 TDi - Lava Grey
              • phil2.016v
                • Mar 2006
                • 300
                #22
                it's boosting at 16 psi now after a re plumb of the standard boost controller and a Baily recirc valve.
                Is that more like it? It pulls hard now
                Audi 80 2.0
                E21 BMW 316
                Ibiza Cupra Sport
                Mk3 Golf GTI
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  #23
                  Sounds spot on (except that an S2 boosts in BAR not PSI )
                  Stock, it should boost to around 1 bar (around 14.5 PSI) under normal acceleration in 3rd gear and above. In 4th gear and above, when booted, it should overboost to 1.15 bar (just under 17 PSI) and then drop back.
                  Overboost is supposed to last for up to 15 seconds, but I have never found a hill long enough and steep enough to stop me running out of revs
                  Cheers n
                  Si
                  • phil2.016v
                    • Mar 2006
                    • 300
                    #24
                    My gauge only shows PSI
                    That sounds about right then although I haven't seen 1.15 BAR on overboost yet, better fit the Mark H mod then!
                    Phil
                    Audi 80 2.0
                    E21 BMW 316
                    Ibiza Cupra Sport
                    Mk3 Golf GTI
                    • oilman
                      • Jan 2006
                      • 996
                      These rattles are indefinately caused by oil starvation so using a thicker oil is not the cure. It's flow that's needed and thinner oils are often the best cure.
                      Simon
                      Use the code S2F and get 10% Club Discount
                      oilman's website for BMW engine oil and much more - register for news and offers
                      email: sales@opieoils.co.uk
                      phone: 01209 202944
