does anybody have experiense on converting 7A block and head to ADU specs ?
is it strong enough ? i know about the diferense in bore, but is there anything more i need to know ?
thanks !
I have an original Audi workshop training book at home for the 7A and it has a section that talks about the sodium filled exhaust valves, i remember reading it as it tells you how to dispose of them. It was something like cut valve in two, place in bucket of water and quickly retreat 5 meters away
There was mention on the forum here that only the early upto 1990 models with the 5-1 manifold had the sodium valves, 91 onwards with the cast manifold didnt apparently. Not sure it thats true. From what i've seen the early heads only had two studs per exhaust port where as the later heads had the extra stud holes machined so an S2 manifold would bolt upto it.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
The part numbers for the 7A and 3B/ABY/ADU exhaust valves are different. They are both 98.2mm in length, however I can't confirm the valve head diameter
Does look as though, at least on the parts listings, that the NM/7A used the 611D and the 3B/ABY the 611B.
Strangely I was talking about this last night with SteveH. He pointed out that the 7A valves from the head he has have the distinctive shape of sodium filled valves. They also appear to be non magnetic on the valve face. We applied the same test to some ABY valves with the same result.
I have just checked some other valves and it looks as though the top parts are magnetic and if you move the magnet down the stem there comes a point when it becomes non magnetic. I'm not sure why this is the case or whether it is a valid way of identification.
Perhaps both the 611B and 611D are sodium filled but the material spec is different to account for the turbo aplication. Some naturally aspirated engines also use sodium filled valves.
