I have looked on the search bar and not found much stuff of any use, who here runs a boost guage, i would like one, so i know my car is running ok, any ideas comments will be most help full please
also where could it go, shame theres not one as standard with the vag gauges.
I've seen a number of boost guages that are fitted into the centre air vents, which seems a really neat solution, unfortunately I don't have that option as my flip out sat nav screen partially obscures the vents
MidnightBlueS2 - The pic of you'res in the dark looks like you've got the boost gauge being shown in digital on one of those display-front headunits...and then u look lower down and see a normal head unit. Good idea though, very neat.
...ever since I floored you I knew that I loved you!
I'm after some boost gauge related advice.
I'm torn between two VDO gauges. On one hand I have one with a white background (keeping the stock theme throughout the car) which reads in Psi. On the other I have the VDO 'vison' style that has a black background and reads up to 3 bar.
I'm probably going to go with the white one but I wanted a gauge that read in metric. I also want to stay with a VDO gauge.
