Head Gasket!
  • sacs2
    • Feb 2005
    • 83
    Head Gasket!
    HI people i dont get on here much but would be real gratefull if someone could help me out a bit here.
    Last night while gettin the better of an M3 down the A1 my 3B decided it blow its head gasket and was wondering if any of you had any thoughts on the replacement one i need?
    Should i use original Audi or are after market ones ok? or should i get a special one?
    IF it aint broke DONT! fix it
  • s2dude
    • Nov 2005
    • 1631
    It would be worth checking for the cause of why the headgasket blew as well.....
    but I would say if you planning to stay stock then an aftermarket one form say GSF or ECP will be fine.....
    BUT// if you plan to upgrade power in the near future, depending on by how much and what means I would get a metal HG from 043efi.com (I think thats the name?) and if you are going for BIIG power then get one that drop the compression ratio a bit
    Good Luck
    • Billman
      • 4129
      Use the OEM One made for the RS2! It is the only one available from Audi for 3B, ABY and ADU!
      Go Holset or Go RS4
      • Jon441cc
        • Dec 2005
        • 2061
        I agree, the Metal HG is plenty good enough, drops the compression ratio to 9:0:1
        • sacs2
          • Feb 2005
          • 83
          Cheers m8,
          not sure on the history of the gasket but i figure its been on the car awhile now cause ive done 50 k in it since i bought it and they have been hard miles for the old girl ha ha.
          I am lookin to upgrade soon so the metal one seems like the wise choice i guess.
          I wouldnt mind but it was running great too done a few home mods on it but you know how it is.. you can never have enough power ha ha
          • Corey
            Banned
            • Sep 2003
            • 2793
            RS2 metal head gasket and ARP head stud kit. Bit more expensive to buy than the stock bolts but they are a fit and forget, there is no need to ever replace them and it makes fitting a head so much easier.
            Oh and available from me...
            Corey
            01636 822288
            • Jon441cc
              • Dec 2005
              • 2061
              Corey how much are the ARP studs ?
              • s2_bo
                • Oct 2005
                • 6067
                Dont suppose you have metal rocker covers as well as the metal head gasket + ARP stud kits???
                If you do id like to get my hands on a whole kit.
                91 S2 coupé - RIP
                98 S8 - Luxury barge
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  Get Victor Reinz gaskets. They're the same as OEM but much cheaper.
                  P/N 02-29335-01 for the head gasket set. Thanks to Porkkis for that No.
                  ARP headstuds are on my wishlist, so I'd be interested in a price too.
                  SS
                    Good Luck
                    The one from GSF and ECP are not aftermarket they are Victor Reinz gaskets exactly the same as the Audi ones.
                    GSF do a complete gasket set part number 11502E which include the exhaust, rocker cover, valve stems, exhaust manifold etc
                      Dunno if the rocker cover could be made into a metal gasket, it's slotted onto the rocker.
                      Corey?
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        Do you want a set of push-rods with that rocker cover?
                        I think you guys mean cam cover. I've got a metal cam cover.
                        SS
                          Where from?
                          • Corey
                            Banned
                            • Sep 2003
                            • 2793
                            £108+VAT and shipping
                            if you can find exactly the same product in this country (the UK) for cheaper I will try to match that price.
                            Corey
                            01636 822288
                            • Corey
                              Banned
                              • Sep 2003
                              • 2793
                              Could we clarify which bit Jamo is on about because I was just out pulling a pinto to bits for him???
                              Corey
                              01636 822288
