V6 coupe pas pump replacing
  • Crawford_S2
    • 1555
    Got to replace this pump on a 94 v6 coupe and can't see how it adjusts/tensions the belt. Any BTDT?
    Ragusa Coupe gone!
  • Crawford_S2
    • 1555
    Anyone? It is rather old, its by J R Hartley
    Seriously though one of you reprobates must have had an old bus like this apart at some point, they are always on the fritz
    Ragusa Coupe gone!
    • kninio
      • Aug 2004
      • 641
      • Home: Lebanon Current: United States
      u have to push the tension down its like pressured up , u have to put on it a key it have a hole for it then push it down so the belt will be free and the same when u want to rest the belt.
      do u have a 2.6 or 2.8?
      • Crawford_S2
        • 1555
        2.6 bro, whats this key thing
        Ragusa Coupe gone!
        • kninio
          • Aug 2004
          • 641
          there is no key its same as 2.8 as 2.6 , did u replace it or not yet? to take off the belt just press down the tensioner and it will loose the belt then u can take it off and install the new pump and then push it back and insert the new belt. i will try to find you picture and sorry for my english , but u know such a tool to push on it and press it down via the toll its a key which look like L and it can be use to adjust the inner of the headlamp if u understand me what i mean.
          • Crawford_S2
            • 1555
            Thanks for the help
            Ragusa Coupe gone!
            • kninio
              • Aug 2004
              • 641
              look this picture.. near the tensioner is something like nut u put the key on it and turn it downward so it will loose the belt i think now its enaugh clear.
              • Crawford_S2
                • 1555
                Excellent, i know exactly what you mean now dude!
                Ragusa Coupe gone!
