More Problems Help Please
  • iain1067
    • 984
    Guys and girls
    i need some advice please, i have on order a 1.8T coil pack conversion which i hope will cure the high boost misfire that i have. Whislt still driving the car this morning vag com shows i now have 2 further problems. I got to work and stank of rotten eggs aka cat converter working overtime. The codes i have are as follows
    1. G28 (which i think is the crank position sensor) is saying implausable signal, this is a code that somes and go's and has done since i got the car in january this year.
    2. Lambda is now showing up too, saying that it's out of range, when i try to clear this one it comes straight back on the vag com.
    Have i screwed up the lambda sensor???? and should i replace the G28 sensor??? If i do need the lambda other than audi where can i buy one that already has the right plug on it rather doing a cut and splice job??
    Thanks
    Iain
  • Mikes2
    • 1704
    http://www.justlambda.co.uk for the lambda probe
    Mike
    http://www.s2-audi.co.uk
