Hi
I have some very weird problem.
Setup:
k26/t04e
green injectors
adu ex. mainfold
bigger intercooler
etc,
Problem is: it peaks just so much I turn wastegate. Example . . . max boost is ca. 2bar . . . but at the redline it drops to 1,4. Even if i turn wastegate back and turbo peaks to 1,7 . . . it drops still to 1,4 no matter witch gear.
I think it' s not any boost leak, because @ 2bar and 4gear it hold nice pressure before it begins to drop. And 90% of pipes are new, because of new interooler.
I' ll tried even to disconnect n75 from turbo . . . still drops to 1,4. Tried new wastegate spring, still the same.
Last year there wasn' t that problem . . . it was holding a pressure to redline just fine. Car runnig normal, feels good, but the top end was better before.
I' ll remember just one day when car was going better than ever @ the top end, but that was just one day.
There's no any codes in ECU, a/f gauge shows rich . . . I' m running out if ideas.
I' d tried to search at the forum, some problems was alike, but . . . not exactly the same.
anyone?
Setup:
k26/t04e
green injectors
adu ex. mainfold
bigger intercooler
etc,
anyone?
