New sensor still got code, what now??
  • iain1067
    • 984
    i have replaced what i thought was a failing engine speed sensor (G28) on my S6
    but it's still throwing me the code, intermittant signal, car is even now
    starting to cut out on me, not at speed but slow stuff like pulling in the
    drive or coming up to a junction, any further ideas on why this should be??
    I know this one runs off the flywheel teeth, am pretty sure i don't have a
    damaged flywheel (like missing teeth)as the car starts fine, had a recent
    clutch done but the car has always thrown this code ever since i first got it 5
    months ago. Bentley doesn't seem to show any sort of gap adjustment on this
    like abs sensors for instance. Where to look next??? I am stumped
    Iain
  • Crawford_S2
    • 1555
    Could it be the engine speed sensor on the camshaft? Did mine recently but it started with other symptoms. Mine used to refuse to start!
    Ragusa Coupe gone!
    • iain1067
      • 984
      I haven't had that code yet, but i did have the code for the ignition timing sender too (only once) i have a new one to go on today,
      Iain
      • merlin's S4
        • Jan 2005
        • 1539
        I'd be tempted to ignore the engine speed sensor and look elsewhere. That code will always show up when the engine isn't running but even when it is running, I believe they've been known to show up on a diagnostic check! Mine does sometimes!! I chased a similar problem around a year or so ago and I too replaced that sensor but it didn't solve the problem. I eventually traced it to an air leak.
        • iain1067
          • 984
          thanks at least i have 2 new sensors and 2 spare old ones lol, might have a poke around and see i have any leaks i don't think so but you never know.
          Iain
          • rj scotty
            • May 2006
            • 2195
            I got the same problem now
            Did we get this one sorted ?
            BUT I DON'T WANT A NEW CAR!
            1995 S2 Avant, Volcano Black
            • Acidburn
              • 13459
              Does it happen at slow speeds when the clutch in down and no accel pedal?
              • S2_Dave
                • Aug 2005
                • 456
                Is your car standard? Does it happen from high revs, but if you plip the throttle as revs drop below idle you can sometimes catch it?
                David
                '91 3B S2 Coupe
                • rj scotty
                  • May 2006
                  • 2195
                  Happens only at low engine speeds, on and off load will cut out at idle now and again.
                  Very intermittent geting "00513 inplusable singnal g28 intermittent"
                  Cleand the g28 with some IPA this improved things slightly but could have been coincidence.
                  Only other code is the good old "00561 mixture adaptation not reached intermittent".
                  Car is standard ABY with AMD chip.
                  cheers
                  rich
                  With a big shameless PLEASE HELP ME
                  • Acidburn
                    • 13459
                    I'd also clean the idle valve as if your pulling in to your drive etc at low speeds dip the clutch it might not be able to catch the revs as it goes down as i've seen that on a couple of cars. Worth a go anyways.
                    • 220bhp
                      • 2578
                      • Home: United Kingdom
                      As above, try cleaning the isv with some wd40
                      • A80Avant
                        • 10873
                        • Country: Greece
                        561 could also be the MAF.and the MAF is known to create poor idle problems.Im having the same 561 code now,and only appears when the car is hot.Im pretty sure the maf is out.
                        • rj scotty
                          • May 2006
                          • 2195
                          Don't think its idle valve related as it happens mainly at part throttle more so when under load.
                          Only very occasionally at idle but ill give the valve a clean anyway
                          Think I'm going to replace the Maf as 00561 won't go away even after a few maf baths.
                          And unless anybody has a better suggestion a new g28 as well.
                          Any body got the part number for g28.
                          cheers
                          rich
