Oil in crossover pipe
  • iain1067
    • 984
    i seem to have rather a lot of old looking oil in the cross over pipe (urs6),
    like when i took the michelin man hose off tonight it pee'd all over the drive,
    should i have this amount of oil here?? and if i shouldn't what can i do about
    it??
    Iain
  • Corey
    Banned
    • Sep 2003
    • 2793
    it??
    Iain
    A lot of it is from the crankcase breather, the rest is fuel vapour's. The amount depends on how clean your engine is. I regularly take that hose off and give it a clean.
    Corey
    01636 822288
    • iain1067
      • 984
      Time for me to do the same, should i also take the intercooler out and give that a flush too???
      Iain
      • Corey
        Banned
        • Sep 2003
        • 2793
        Iain
        You can do but the MM pipe is the lowest point so it all usually collects there.
        Corey
        01636 822288
        • iain1067
          • 984
          Good point, probably a bar steward to get out anyway.
          Iain
          • s2driveruk
            • 12696
            any way to clean eveything using some additive or flush etc? I know this is not the right thing to do but just cleaning one pipe doesn't cure the problem i guess?
            1992 3b S2 Coupe
            • Corey
              Banned
              • Sep 2003
              • 2793
              you will never cure the "problem" because of the way the breather system works, you will always have this vapour on a stock car.
              Corey
              01636 822288
