ok guys.
As part of my ongoing work with the S2 since fitting my new Defi rep boost gauge the other day (love it!!) Ive found out why my car seemed a bit gutless over 4 k rpm// (it takes off very well then.......just seems to go flat??!)
and I think the fact it is only boosting to 4 PSi may be a Big Factor!!!
Ok. So I Vagcommed it and the Intake Air Temp sensor was highlighted as faulty...So I tested it and it was ok resistance wise but I found one of the connectors had come unsoldered
so I repaired it and NO Vagcom code now..... :mischeif:
BUT// It still only Boosts to BANG ON 4 pis. no fluctuation in that level??
Im suspicious the MFTS might be faulty as the car seems to take ages to get to temp via the gauge but Im not sure.....and it only does 4psi even when in the middle of the temp gauge.
So on to the next idea that the Wastegate Frequency solenoid might be knackered?? though I thought this would limit boost to FIVE Psi and not 4psi??
Any ideas please guys?/
TIA
so I repaired it and NO Vagcom code now..... :mischeif: BUT// It still only Boosts to BANG ON 4 pis. no fluctuation in that level??
TIA
