number 1: engine water temperature does not climb above the bottom of the range even when stood at rest. the thermostat has been replaced, so could this mean the sensor is faulty?
number 2: i have a new hybrid turbo fitted, but this has not cleared up the boost problem i have been experiencing. on acceleration the turbo boosts to about 9psi then drops back to 5-6psi. boost hoses need replacing?
thanks in adveance for any help provided
