When fitting the new tubular exhaust manifold the turbo moves away from the block and the existing oil feed and return pipes are too short. I am after the two pipes so that they can be extended.
I want to keep the originals just in case I need to return to the standard manifold. Either post here or PM me with your offers.
I can get the pipes made up no problem but it is the actual fittings that are the issue. They are machined to fit exactly around and onto the turbo location plate/area and are quite intricate.
