a question about the cooling system
  • s2_southwest
    • Oct 2004
    • 823
    Ok i've had a look on s2 central but i got a bit confused (easily done)
    my problem is that my cooling fan never kicks in (im sure it did at one point) To test the fan, can i should out the sender at the bottom of the main rad? Will this initiate the fan? If not, i take it that i need to short the smaller one on the water manifold. But, after the engine is shut down, and the electric TCP is running, should the fan run too at that point? Just need to test out the fan really and find the suspect sender and/or relay. Ive checked the fused and thats all ok, and im pretty sure the TCP pump works coz i replaced it only a couple of months ago and i think the water level rised enough in the expansion tank to prove this
    cheers in advance.
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
  • WabTheKing
    • May 2004
    • 2567
    yes shorting the wires on the sender at the bottom of the rad should make the fans kick in, not sure what the 2pin one on the manifold does,
    • s2_southwest
      • Oct 2004
      • 823
      i think its for the after run pump, not too sure though..
      Will try the one on bottom of rad and report back
      • s2dude
        • Nov 2005
        • 1631
        This may be very useful to you
        hth
        • s2_southwest
          • Oct 2004
          • 823
          superb, that is a great help!! I tried shorting out the sensor on the bottom of the rad to see if the fan came on but i heard a clicking and nothing happened. I think it may well be the actual fan that has broken. Doesnt look like an easy job to replace!! doh
            Have you got aircon? if not it's not that bad, if you have aircon
            • s2_southwest
              • Oct 2004
              • 823
              i do have aircon yes, i feel like ripping it out, its no good anyway. just open the windows
              • Bowlerwell
                • 1052
                hth
                Sorry, I don't mean to hijack, but i'm very much enjoying the diagram at the top of this page. I assume it applies to S2s?
                But where does my Aux. Rad fit in? And where under my bonnet is my 'Heat Exchanger'?
                Thanks!
                JohnB
                John Bowlerwell
                Electronic Engineer
                Present:
                Nogaro Blue RS2 - TOE
                Previous:
                Kingfisher Blue S2 - UAA
                Volcano Black RS2 LHD - DEX
                  Thanks!
                  JohnB
                  No disrepect but you've had this explained where the aux rad is in your own thread
                  The heater exchange is called the heater matrix on the S2 and is behind the dash, a bitch to change.
                  You can see the matrix inlet and outlets in the middle of the bulkhead under the bonnet
                  • Bowlerwell
                    • 1052
                    Yeah, I know where my Aux. Rad. is physically located under my bonnet, but in terms of the above mentioned diagram, where is the Aux. Rad. plumbed in?
                    Thanks,
                    JB
                    John Bowlerwell
                    Electronic Engineer
                    Present:
                    Previous:
                    • Paulgo
                      • Jan 2005
                      • 498
                      Thanks,
                      JB
                      It doesn't, as the diagram you mention from above is for the AAN engine in the S4/S6. and that doesn't have an aux rad. It didn't need one as the S4/S6 has loads more room around the engine bay and was able to have a huge rad in the normal position in front of the engine.
                      Paul..
                      Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
                      Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        If you look it's 'T'ed off of the main rad's top and bottom hoses.
                        SS
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          Where the arrows are in the diagram.
                          SS
                          • Bowlerwell
                            • 1052
                            Thanks folks!
                            John Bowlerwell
                            Electronic Engineer
                            Present:
                            Previous:
