--- This really works and could save a lot of time and hassle ---
As everyone is aware the Sump plug is a absolute PITA to undo when changing the oil.
I tried for about 30 mins last night and didn’t manage to get it to budge in the slightest.
The bolt was loosing more and more of its edge and almost rounded off.
So i packed away the tools etc. and accepted the fact that id have to get the garage to do it.
Then suddenly i had an idea..(that doesn't happen very often LOL
So i jacked the car up to 15 - 20 cm, and placed a breeze block under it just below the Oil Sump. I then got a piece of veneered B&Q flat packed furniture and lay this on top of the block.
I then took a 17mm socket on a 1/2 inch drive and placed it on the sump plug at about a 90 degree angle.
Here is a rough display (sorry my mspaint skills are not to great…)
I then “Very slowly†lowered the car down, checking constantly to make sure that the socket was properly attached to the Sump plug and not slipping off.
The veneered timber moved bit by bit across the block as the weight of the car was forcing it down.
With in about 20 seconds there was snapping sounds as the sump plug came lose.
I then jacked the car up again, removed the block and timber, and easily undid the sump plug.
The rest is self explanatory.
Using the cars weight to undo the bolt is very effective, but make sure that you have a good angle on the drive or breaker bar.
Do not try to lower the car if the attachment is vertical, this would result in a lot of damage.
This method took about 5 minutes and is effortless.
Hope this is of some use to some one, cheers.
Bo
)So i jacked the car up to 15 - 20 cm, and placed a breeze block under it just below the Oil Sump. I then got a piece of veneered B&Q flat packed furniture and lay this on top of the block.
Bo
