Wat do you know about Bosch 280 150 558 injectors 440 ccm 14 ohm is the same whit RS2 injerctors??
RS 2 injectors ????
Those are Ford Motorsport "Greentop" injectors:Originally posted by marius_s4Wat do you know about Bosch 280 150 558 injectors 440 ccm 14 ohm is the same whit RS2 injerctors??
Bosch part number 0 280 150 558
Ford Racing part number M-9593-F304
326.8 g/min flow @ 3 Bar
14.5 Ohms resistance
EV1 design type
standard body
Maybe this helps.
Sau200 20vt 88' 3b, human carrier
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.com -
Bosch 803's or RS2 injectors are 4.5 Ohms and 286 g/min at 3 bar so NOT a direct replacement without a remap of ECU.Comment
