Engine demage what hapend???
  • marius_s4
    • May 2006
    • 57
    • Country: Romania
    Today i blow my engine i dont know wat was the problem bat this is hapend
  • marius_s4
    • May 2006
    • 57
    • Country: Romania
    Please help
    • marius_s4
      • May 2006
      • 57
      • Country: Romania
      • volcano rs
        • Jun 2005
        • 2265
        looks like oil starvation possibly oil pump
        • marius_s4
          • May 2006
          • 57
          • Country: Romania
          everything was ok the oil presure was 4 bar oil temperature 90 bat i was runing in hi rpm 6000-7500 and the engine start to '' tac tac tac " and that is the end.
          • jade
            • Jan 2005
            • 1811
            At these rpms it should be 5 bar ???
            RS 2 580HP
            • SteveH
              • 4460
              4 Bar isn't too bad at full running temps, it all depends on type of oil, etc. You've definately spun the bearings, this is often due to oil starvation. Have you made any tuning changes lately? If not, have you checked the oil pump?
              91 Modded 3B
              14 A6 Avant Black Edition
              • marius_s4
                • May 2006
                • 57
                • Country: Romania
                I change my turbo whit an k27 that it all and i will must complete my upgrad
                • marius_s4
                  • May 2006
                  • 57
                  • Country: Romania
                  and the oil was castrol 5w-40
                  • jade
                    • Jan 2005
                    • 1811
                    i never see under the 5 bar when hot 2.2 at idle volveline vr 1 10 60 oil
                    RS 2 580HP
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      my hot idle is low, its more like 2bar with purple 5 60 silkline pro i think????????(had a few beers) please correct me if i am wrong!
                      Chef
                      • BrianSmith_S2
                        • Jun 2005
                        • 1342
                        • Home: Northern Ireland Current: British Antarctic Territory
                        • YumyJager
                          • 58
                          Looks like yours was flawed somewhere in the manufacturing process.
                          This is what my spun rod bearing looked like:
                          1990 Coupe quattro 20v, no T
                          1992 S4 20v, very much so T
                          • caterpillar
                            • 2480
                            spun bearing
                            the engine does not see clean inside,read: to LONG oilchange intervalls, i have older engines(from 84) they doesnt seen like this innside. i have older diesel(2,4 and 2,5) with 400000km on,theydoes se like this. the cranc does need rebuild,or change it.
                            then you need rebuild the engine,because the trash from the bearing.and you really need to clean it in the oilgallery ..the bearings DOES cost a lot of money,and lot of work.
                            • iain1067
                              • 984
                              Might as well source and fit a good used engine by the time you have stripped everything down and cleaned it, be easier and quicker. You won't get all the bits out of the oil cooler for instance and it's then just a matter of time before you find bit's floating around again. I would swap the oil cooler too whatever route you take.
                              Iain
