turbo
  • madS2
    • Nov 2005
    • 552
    turbo
    turbo seems to be leaking water/oil?mixture of both.any idea what this is?
    Looking for an S2 ABY
  • james_bufkin
    • 59
    not good.
    Bad lines,
    bad bearings.
    bad gaskets,
    Cracked center.
    • madS2
      • Nov 2005
      • 552
      new turbo then?
      • james_bufkin
        • 59
        Not if its the lines.
        If its leaking from the bearing its a rebuild.
        If its leaking from the housing its kaput
