AAN ecu connector pinout
  • Petya
    • Sep 2004
    • 89
    Hello
    Where can i find AAN s6 motronic ECU pinout? I need to make in next days adapter between cabel loom connector and DTA ecu. I will use one dead computer connector.
    "you don't make history by following the rules, you make history by sizing the moment..."
  • iain1067
    • 984
    This may help
    • Floddy
      • Dec 2003
      • 222
      Should be the same as AAN.
      www.sjmautotechnik.com should have some info also.
      Red cars are the fastest ones...
      - Team Irry -
      • Petya
        • Sep 2004
        • 89
        Thx
        • Billman
          • 4129
          Does anyone know if there are any differences on the ABY and the ADU Pinout?
          Go Holset or Go RS4
          • DJones
            • Jun 2005
            • 2020
            I think the only diff is the firing signal for spark plugs 1 and 3 are reversed for some reason.
            Might be wrong but it rings a bell!!
            • Billman
              • 4129
              Anyone else knows something more about it?
              Go Holset or Go RS4
