Help me please, engine misfiring problem
  • S2_NZ_BOY
    • Jun 2006
    • 2
    hey guys,
    just bought a 1992 Audi S2, hehe and loving it, i got a bit silly and cleaned it and polished it then decided to clean the motor, sprayed it all down with caned Degreaser, hosed it of with just a normal hose, drove it back into the garage and it was running on four cylenders, parked it up for the night, and then tryed to start it again in the morning and no go, its like it wants to fire but it doesnt, put new plugs in it, blew out water in electrical plugs and tried again, no luck, tow started it, backfired, then ran again, really ruff, and once again on 4 cylenders!! i have tried everything and no luck,
    theres no blowen fuses,
    where else would water sit or what could it have blowen?
    Please help me on this
    i want my baby to go again
    Thanks
    Sam
  • Fat Audi 80
    • 10547
    Have you been and checked ALL the eletrical plugs? There are loads.
    Have you thouroughly checked all the ignition system including the distributor cap and plug leads etc...?
    Cheers,
    and
    Steve
    The Perfectionist
    • SteveH
      • 4460
      If you haven't already removed the distributor cap and checked for water, you're going to have to check that for sure. It's a pig to get at too! Follow the plug leads to the underside of the inlet manifold....good luck!
      91 Modded 3B
      14 A6 Avant Black Edition
      • S2avant450
        • Nov 2005
        • 32
        • Country: Denmark
        Originally posted by S2_NZ_BOY
        hey guys,
        Thanks
        Sam
        Hello
        I had similar problem, after checking all the things you have. I reassembled my airflow meter, and found it a bit moisty. So dried it with heater, assemled again. And then the engine spun as usual...
        /Thomas
        • BrianSmith_S2
          • Jun 2005
          • 1342
          • Home: Northern Ireland Current: British Antarctic Territory
          Cheers,
          and
          Steve
          i followed the cleaning sequence as outlined on the forum where u use engine degreaser, followed by hosing off, then vynl/rubber protector dried off by running engine with bonnet(hood) down to dry everything. it worked a treat, it produced a very clean and sparkling engine bay, but reduced me to 4 cylinderso : . on both occasions it was moisture down the 5th sparkplug bore that was the culprit .
          cleaned up all 5 plugs, cleaned surfaces that the spark plug washers contacts and sprayed contact cleaner (not wd40) on coilpack contacts and it fired up like a dream, and ran very smooth.
          • S2_NZ_BOY
            • Jun 2006
            • 2
            got it Going
            Hey guys, thatnks for all the help, it turns out that the Dizzie Rotor had about an inch of play in it so i must have got water someware and made it miss and make the rotor move in the play it had, then it was fireing in the wrong order, so i got a ner rotor and cap and away it went
            thanks guys
            Sam
