after reading the few threads on leaking fuel lines i have decided to change mine after spotted leaks. I have cut three lines, One from the passenger side of the fuel pump, i hope this correct, and the two which go right up the back of the car where they go into rubber hose pipes with jubilee clips attached. While i am currently waiting to get more pipe to finish the third line, i have come across a problem. When doing the job i should have changed the pipes one by one, but in hast, i didn't, therefore i am not sure what goes where. can someone describe to me best where each pipe should go. Does the one i cut from the pump go to the line most located at front passenger side or middle or drivers side of the three pipes i cut up front just by the heat shielding?
I hope i have explained this properly as i am not very mechanically versed.
cheers
cheers
