i am rebuilding my head and just wondered about the camshaft carrier caps and which caps in the right sequence and right way round. 1-10 does anyone have any ideas?
camshaft carrier caps?
previously owned audis:
1987 Audi 80 1.8E
1990 Audi 80 sport
1989 Audi Coupe 2.2E
Current car:
1995 Audi S2 Avant LHD
Tags: None -
They have numbers on them, Pic below will show you the direction, beveled edge facing the rear of the car, and the rear most two have a flat top. I dont have any closer pics but you may be able to figure out from these images which number goes where...
Mark.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express -
Ermm what you should have done was to mark the caps so that they went back on in the right sequence, i read somewhere alongtime ago that they are line bored to fit the actual camshaft and therefore wasn't advisable to use caps off a different engine. Correct me if i am wrong someone, it's in the dim distant past that i read that.Comment
Correct, there mounted on the head then machined. Just remembered there is a diagram in my Bentley manual showing which number cap goes where so if your still stuck let me know and i'll dig it out....91CQ20v - Gone to a new home
94S2Bus - The Emerald ExpressComment
As an aside i do know of people that have cracked a cam cap by over tightening it, so be carefull, and the same people went down to the scrapyard and got one off another car, worked fine so i guess there must be a little tolerance in these things.
IainComment
The caps are inline bored on the S2 so theorectically it's new head time if the above happensOriginally posted by iain1067As an aside i do know of people that have cracked a cam cap by over tightening it, so be carefull, and the same people went down to the scrapyard and got one off another car, worked fine so i guess there must be a little tolerance in these things.
Iain
