V6 heads overhaul
  • WabTheKing
    • May 2004
    • 2567
    V6 heads overhaul
    planning on doing stem seals etc on the A4 as its smoking like a behatch
    anything else to look for, someone mentioned zaust valve guides are known to wear?
    its a 1997 2.8 30v with an lpg conversion with 167,000
    been quoted £400 for the heads to be done dont fancy lapping in 30valves
    cheers
    will
  • hiltoa
    • 1060
    • Home: United Nations Current: England
    Sorry, can't give you known issues with the Audi V6, but I'm not long off doing the same with my VR6 - it's started smoking like a behatch too... (Funnily, seems to be since MRC gave it a tweak, obviously doesn't like the extra power )
    I'm hoping it's just the valve seals, but I'm kinda prepping myself for guides and rings replacement. (at least I only have 12 to lap ) It only seems to smoke noticably at >5k but then it's a bit like a 007 secret weapon Not good when showing chavs a thing or two.
    I've been using Mobil1 15W/50 for a while now, wonder if that has anything to do with it.
    Nothing feels fast for long...
    2000 Audi RS4 - Kingfisher Blue ~+~ 2004 Audi Allroad 2.5 Tdi - Ebony Black Pearl
    • WabTheKing
      • May 2004
      • 2567
      mine only does it after you have been coasting down a hill or sometimes if its been left ideling for a while,
      • hiltoa
        • 1060
        Sounds like yours is dribbling, and mine is getting pushed.
        Mine sounds worse.
        Cue 'fnar fnar' comments...
        • WabTheKing
          • May 2004
          • 2567
          :mischeif:
          • Baldy
            • 469
            • Home: Sikkim Current: British Antarctic Territory
            Will, ring steve at portformance (01925) 724278 in warrington he's done work on the heads on a couple of the cars i've owned he used to do the work on dubsports cars too and was always reasonably priced
            Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
            0-60 4.9
            1/4mile 13.5
            • WabTheKing
              • May 2004
              • 2567
              ta matey, their price is more like it!
              • Baldy
                • 469
                what did u get quoted?
                0-60 4.9
                1/4mile 13.5
