7A Blocks
  • twoqu
    • Sep 2003
    • 3103
    7A Blocks
    Hi!
    Can anyone confirm/deny that the 7A block has the boss for the turbo return line but it is undrilled! I think I remember noticing that it did but lost a few brain cells since then!
    Ta!
  • Mark Halligan
    • 2001
    Originally posted by twoqu
    Hi!
    Ta!
    Robin
    thats correct......just took a pic of THE BLOCK for you
    Mark - Modded
    • twoqu
      • Sep 2003
      • 3103
      Errr....
      That's BLOCK not HEAD!
      Besides the MRC link has a 403 forbidden thingy on it!
      Apologly accepted!
      • Corey
        Banned
        • Sep 2003
        • 2793
        Jamo the question relates to the block not the head that you have shown in the link.
        All the turbo return is, is a modified core plug. You can knock the old one out and insert the correct one with the return boss on it.
        Corey
        01636 822288
          Excuse me i've been drinking lol
          • Corey
            Banned
            • Sep 2003
            • 2793
            doh a thousand people respond at once and of course I have to assume (incorrectly) he means the water return. sorry just realised you mean the oil
            Corey
            01636 822288
            • twoqu
              • Sep 2003
              • 3103
              Cheers Mark!
              Its useful having a lots of stuff hanging around isn't it!
              Could you tell me the block p/n number on the other side above the engine mounting bolts, if its not too much trouble!
              Bit concerned over an engine I have. It looks like a 20V, has the oil return hole but with a 054 rather than 034 p/n on the block!
              • twoqu
                • Sep 2003
                • 3103
                Mmmm..
                Without wishing to be a pedant. I would call that the turbo water supply line, at least with the engine running!
                • twoqu
                  • Sep 2003
                  • 3103
                  OK!
                  Panic over! Realised I had another block to cross reference. It was the ETKA p/n that was causing the confusion. Thought it was too neat a job of drilling!
                  Thanks to everyone that responded!
                  Should have borrowed Jamo's beer goggles!
                  • Mark Halligan
                    • 2001
                    Robin
                    just in case you still need it, the P# on the side of the 7A block I have is 054 103 121
                    Mark - Modded
