More info wanted on Garrett T04E-50
  • meep
    • May 2005
    • 203
    Hey.
    Id like som info on the Garrett T04E-50. All i can find is compressor maps and well i suck att calculating stuff on thoose. So what is the general opinion on these turbos on a S2 machine. The car that is interested in this turbo has a built bottom end so tourqe isnt a problem. Its only gona be stressed to 380-400 hp though so is this the right turbo for them?
    Here are some pics on the turbo in question.
    If you can stretch your budget i'd go for a garrett gt2871R or gt3071R with K26 hotside with a .63 AR
    Have a read http://www.motorgeek.com/phpBB2/view...hlight=gt3071r
    • Tommy200rs
      • 285
      I measurements what is the narrowest point in the entry. Though your measurement seems to be ~60mm territory.
      Could you measure the exit also (the turbine blades exit in the housing) in mm ?
      The turbine wheel seems to have very hevy axle (big fat turbine axle nut)
      If you select that the entry should be more than 55mm+ then the Garret ball bearing series turbos are better choice when the overall rotating masses are relatively big.
      • meep
        • May 2005
        • 203
        Ill have a look at having it measured but the thing is that i can get this turbo pretty cheap but ifi its lag hell then i wont go for it. But if its ok then i think its the choise for me.
        Will read upp on thoose in the link above thnx
