There has been discussions on how to modify the metal laminated head gasket. The idea is that
a) it needs to be thicker because a head has been taken off and thus machined flat - taking 0.002" or 0.003" off - Is that about right?
b) a lower compression ratio means you can run more boost.
The RS2 (metal laminated) Head Gasket is made up of four layers.
The top and bottom layers are 0.008" thick and also have a pressing in them round the cylinders, coolant and oil holes.
There is a shiny metal layer below the top layer - this is 0.004" thick.
Then you get the centre section that is 0.040" thick - now this looks as if it is 2 layers but bonded together.
The 4 seperate layers are not bonded together - they have brass cheapo rivets holding them together. I was also surprised (although I have never seen headgaskets before, so what do I know!) that big holes for the cylinders don't have one of the layers edges rolled so that there aren't multiple edges in the cylinder - Am I making Sense?
Anyway - How do I modify this (I am getting a second headgakset) so that I have lower compression? I was originally going to put 2 headgaskets on but this seemingly eventually blows. I don't want to get into getting a new centre one laser cut!
And can anyone do some sums to tell me what difference in compression ratios I would see with diffrent layers int he headgasket?
