is this good for AAN,ADU,ABY,3B engine?????
Wat Crankshaft is this??
i dont think there are any BIG difference on any il5 crank. if the cranc are the std stroke 86,4...it will fit right in. check out the oilpump, and the valve who got the oil to the head,and cams.
psst: that pics are from a petrol block
have you seen the diesel ones
There are 2 different cranks - the diference being the size of big end journals (some have 48mm whereas the others have only 46mm). I know this as I had problems when I bent my crank at GTI International a couple of years ago and needed to source replacement.Originally posted by caterpillari dont think there are any BIG difference on any il5 crank. if the cranc are the std stroke 86,4...it will fit right in. check out the oilpump, and the valve who got the oil to the head,and cams.
ChrisLast edited by jogi730; 4 July 2006, 08:55.Audi 90 quattro (Typ 85)
20v turbo conversion
sigpicComment
Oh dear, not you as well?Originally posted by mcandmar"I bent my crank at GTI International" how on earth did you manage that? ..respect
Well this was my very first post on this forum - how did you manage yours?
ChrisAudi 90 quattro (Typ 85)
sigpicComment
