Problem accelerating under WOT
  • s2carlo
    • 252
    Yesterday I experienced (and reproduced) an problem.
    When accelerating with WOT following occurs:
    - turbo pressure goes up to 1.1 bar i.s.o. 1.5 -1.6bar;
    - car starts stuttering, jittering above 160-170kmh;
    - car doesn't accelerate anymore (although turbopressure is up);
    - car hardly reaches 200kmh.
    If I then release the throttle a little:
    - turbopressure drops of (a small plof is heared)
    - the car stops shaking, and stuttering and accelerates again, although not as it is suposed too
    - car reaches 220kmh i.s.o 260kmh that it reaches before easy;
    Any ideas & good tips are appreciated
    Thanks
    Carlo
    No power, no glory!
    S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
  • s2carlo
    • 252
    just putting it on top again
    No power, no glory!
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      could be your coil packs
      • nigelm
        • 150
        Juddering
        Loose spark plug is the optimists diagnosis.
        Cheaper than coil pack failure.
        Have a look.
        nigelm
