Oil Pipe work
  • ian_jemo
    • Aug 2004
    • 284
    Oil Pipe work
    Hi all
    Since I over oiled my car I am having a problem with the performance. I think I might have a blockage somewhere where all the oil runs.
    Can someone tell me all the pipe work which carrys oil and where there could be a possible blockage?
    Also would a blockage of this type effect the performance of the car?
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
    Sounds more like the breather pipes are blocked with the excess oil vapour solidifying in the pipes, do a search for the word PCV valve so you can take it off and check it.
    • ian_jemo
      • Aug 2004
      • 284
      Thanks Jamo will do
      Would this effect the performance of the car???
        Originally posted by ian_jemo
        Thanks Jamo will do
        Yep, well i found it did when i change my PCV valve and cleaned out the pipes and cleaned the firetrap.
        • dan_b
          • Sep 2003
          • 3670
          I certainly found having a ruined PCV system was harming performance too. I have recently been through replacing all this lot as my hoses were all rotten.
          • ian_jemo
            • Aug 2004
            • 284
            Just checked the PCV value and it seemed quite clean. There was oil vapour inside but that was it nothing seemed to be blocked up.
            Is there anything else I should check?
