Incase others like me wondering what the pressure damper ontop of the fuel pump that is omitted in a 044 conversion is:
Bosch fuel injection
PRESSURE DAMPER
A) This device smooths pressure peaks created by the electric fuel pump, that might otherwise result in noise. B) The pressure damper is a spring-loaded diaphragm chamber that responds to dampen fuel pressure fluctuation. The pressure damper is either fuel pump or fuel rail mounted.
