Had latest MOT done yesterday (95 ABY)
All went through okay, wasn't till I got home that I read the emissions results which gave me one concern.
At fast idle the figures were excellent with *very* low CO (0.03 from memory) and HC levels.
However, on normal idle the CO was high at 0.47 (limit 0.50). This is much higher than last year (which was <0.1). HC was very low as well.
Any ideas as to what may be causing this problem at low revs?
PS Lambda was 1.01 and engine well warmed up beforehand.
The lamda probe was replaced around 20k miles ago.
mind you not sure why they would only be affected at low revs.
