My Engine Diagnosis
  • Bowlerwell
    • Sep 2005
    • 1052
    My Engine Diagnosis
    First of all, the garage told me that ALL my spark plugs were loose!!!
    I'll be phoning up the guy that last serviced it then!!
    Will need a new coil pack, and it looks like the oil on my engine was coming from a crack in the head gasket.
    The thread for the spark plug is now non-existent.
    The Audi man thinks that the piston and bore will be ok, but will have to open her up to check.
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
  • dan_b
    • Sep 2003
    • 3670
    Nasty. Good luck
    • porkkis
      • 1994
      These engines tend to loosen the plugs by itself. So there might be no reason to blame the previous service.
        Yes i've noticed this as well.
        • SteveH
          • 4460
          Yup, definately a common problem. However, the torque setting is different for new plugs and plugs that have been removed before. You might want to check what torque setting was used, if any.
          91 Modded 3B
          14 A6 Avant Black Edition
            Really? do you have these torque settings Steve?
