Does 3b have same flywheel as 7A?
  • lynx
    • Jan 2005
    • 125
    Hi,
    As simple question as it is.
    Asking because I' m going to buy SPEC Stage 3 clutch and I need to know does 3b have same flywheel as 7A have.
    with best regards
  • caterpillar
    • 2480
    flywheel for 7A have P/N 034105270K
    flywheel for 3b have P/N 034105270AA
    flywheel for aby have P/N 034105266 E
    • porkkis
      • 1994
      Clutches are intechangeable. AFAIK so are the flywheels. Still every part has different p/n.
      The clutchnet cluches forum people use are "7A clutches".
      • AnLe
        • Dec 2003
        • 291
        7a and s23b are the same as far as clutch goes. The timing stud is in different place and the 7a is way heavyer
        • Sir Buff
          • May 2004
          • 127
          • Current: Switzerland
          I have a 7a-flywheel in my ABY with 3b-sinterclutch from Sachs.
          http://www.audi90.ch
          • AnLe
            • Dec 2003
            • 291
            your timing is couple of degrees off.
            • lynx
              • Jan 2005
              • 125
              it' s nice to heard
              main problem was, is that cluch going to mine s2 3b. They asked my, what kind of flywheel I' m running. I just know stock 3b etc, but I didn' t know if it the same like 7A. They told me that that cluch will go with 7A flywheel.
              anyway, looks like that cluch will go
              thanks guys
