How to take the Fuelpump out!
  • BlackBullet
    • 146
    • Country: Brazil
    Hi people,
    I want to take out my Fuelpump from my RS2!
    So... I need to take out the plastic device too, witch the fuelpump is assembly!
    This plastic device, normaly goes out when we aplly a torque to the left side, but it´s a little bit heavy to make this with the hand!!!
    So... normaly how can we do to take that out?
    Thanks,
    Rafael Pinto
    Audi S2 1994/1995 Avant - Black
    Audi RS2 1994/1995 - Black
  • s2dude
    • Nov 2005
    • 1631
    Originally posted by BlackBullet
    Hi people,
    Thanks,
    If your only replacing the fuel pump you do not need to remove the basket if you are replacing it with a standard fuel pump
    eg// meaning you will not need to modify the basket to fit a "different" pump
    I did this 2 days ago..
    Just remove 14mm and 17 mm size bolts banjo fitting/hose (or 13mm depending on your car/fitment)...undo the connector and pull up say 2cm then twist slightly to pull the fuel pump out
    To refit.....make a note of the direction that the hose points in on your old pump and mark the new pump so it will be correct. Swap the wires and the hose over (using the old clip is ok as long as you remove it carefully/////use a tile cutter to re crimp the metal clip). Then aim the pump into the basket and push straight down.
    You will feel when it seats correctly into the hole ...and it will not go any further...
    Then refit the float carefully and then the locking ring...
    hth
    • BlackBullet
      • 146
      • Country: Brazil
      Thanks hth,
      but I wanto to test my RS2 Fuel pump on my S2 Avant!
      So I need the basket too!
      I will take the pump and the basket from my S2, and fit the RS2 pump with the basket!
      So... my problem goes on... how to take the basket out!!!!
      Rafael Pinto
      • s2dude
        • Nov 2005
        • 1631
        Thanks hth,
        twist it....hard...in the direction of the arrow of the white outer casing
        • BlackBullet
          • 146
          • Country: Brazil
          that´s the point!
          twist it hard....
          I´m afraid to damage the basket... someone have tried to twist it with a screwdriver? or any else idea??
          Rafael Pinto
          • pastures16
            • 2058
            there is a special tool to do the job you will have to pm ben (s2avant) for the part number
            94 s2 avant
            aoc member 1116
            • s2avant
              • 2426
              HERE is the factory manual for removing the fuel pump.
              The tool you need is 3307.
              Ben
              • BlackBullet
                • 146
                • Country: Brazil
                Excelent!!!!
                Thanks a lot!!!!
                Rafael Pinto
                • hajbed
                  • Jul 2006
                  • 146
                  • Country: France
                  Hello,
                  The RS2's basket is not the same dimension that the S2's one?
                  because i m going to changes my s2's pump by a rs2's one, but i only have the fuelpump and not the basket
                  thank you
                  • BlackBullet
                    • 146
                    • Country: Brazil
                    It works..... I have than just change the fuelpumps.... It´s a little bit difficult to fit the RS2 fuelpump in.. but is not impossible!!!!
                    Just forget the clips that will hold the pump... They will not reach the RS2, because is a little bit bigger!
                    Chears!
                    Rafael Pinto
                    • hajbed
                      • Jul 2006
                      • 146
                      • Country: France
                      Chears!
                      ok, thanks.
                      So the rs2's is a little more bigger or a lot.
                      Did you have to force a lot to put it in the basket?
                      Thank you.
                      • BlackBullet
                        • 146
                        • Country: Brazil
                        So... I think that a S2 fuelpump is 2/3 in higher of the RS2 fuelpump....
                        With calm.... you will be able to do it!!!
                        Go ahead!!!!
                        Rafael Pinto
                        • hajbed
                          • Jul 2006
                          • 146
                          • Country: France
                          Go ahead!!!!
                          Thank you very much
