Boost Drop at redline
  • murat
    • Oct 2005
    • 167
    • Country: Turkey
    did a boost leak test, the dv was leaking, cured the problem.
    i also wanted to clean n75(wgfv) when examining the hoses of n75, i found the old owner(********) blocked the hose between wastegate and n75, during on road testing, now car boosts around 0.5-0.7 bar depending on the gear. only onece at 5th gear after 4000 rpm, boost rised form 0.7 bar to 1.5 bar, then ı slowed down, and tried wot again and boost was again low.
    but the rich running is gone i think, because there is no unburnt fuel smell, and car revs smoot till redline. so here i am again with another problem
    will do some investigations with vagcom
    Murat
    • murat
      • Oct 2005
      • 167
      • Country: Turkey
      did a vagcom run
      car gave
      00519 - Intake Manifold Pressure Sensor (G71)
      06-10 - Signal to High - Intermittent
      17-10 - Control Difference - Intermittent
      errors together
      when you wot about 2500-300 rpm, boost is at 0.5 bar in mid gears
      after 4000 when i depress throttle to e.g. %20 and repress then car boosts 1.4 bar
      if you wot from 2500 to redline, it stays at 0.5 bar till redline.
      strange i cant think of anything, any ideas?????
      seems like when car gets hot, problem is more severe, if its cold, it makes it sometimes bu when its hot, low boost is there all the time, unless i depress and repress after 4000 rpm.
      dumb motronic
      Murat
      • murat
        • Oct 2005
        • 167
        • Country: Turkey
        i checked wastegate today, did a vacuum test with mityvac, it holds vacuum well
        my suspect is mfts
        how can i check if mtfs is faulty???
        Murat
        • murat
          • Oct 2005
          • 167
          • Country: Turkey
          oh btw,
          on part throttle there is no limp home
          but after about %80 throttle, limp home mode is there
          before 4000 rpm, limp home is always there
          Murat
          • martinjs
            • 3205
            Originally posted by murat
            my suspect is mfts
            Just disconnect it and see if that changes anything.
            • murat
              • Oct 2005
              • 167
              • Country: Turkey
              #21
              i have disconnected mfts, problem still continues, only change was the temperature gauge was not working.
              Murat
              • murat
                • Oct 2005
                • 167
                • Country: Turkey
                #22
                while i was replugging mfts, i saw that mfts connector is cracked, so maybe its making my intermittant boost problem
                any part numbers for mfts connector???
                Murat
