Tool for spark plugs?
  • ian_jemo
    • Aug 2004
    • 284
    Hi all
    Can someone tell me what size socket fits the spark plugs as I can't seem to find one that fits. And does anyone know where to get one from. I presumed it was a 17mm deep socket would fit but it will not fit down the shaft.
    Ian
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
  • ian_jemo
    • Aug 2004
    • 284
    Just found a thread which says the spark plugs are 16mm, I'll try that.
    Thought I'd check them to make sure there not loose, I have read a few bad threads regarding loose spark plugs
    • YELL MAN
      • Dec 2005
      • 535
      • Country: Shetland Islands
      I found that the handle end of the wheel brace from the standerd tool kit fits the spark plugs. Also be careful if you are using a normal socket set as when i used one then i found the socket was a bit too snug in the hole down to the plug and i had a stuggle getting the socket out again.
      1994 Indigo Blue S2 coupe
      1994 80 Avant 1.9 TDI
      2005 Yamaha Fazer 1000
      1953 AJS Model 18S
      • s2avant
        • 2426
        [partsdaddy]
        The handle of the wheel brace is actually designed to be used for removing and refitting spark plugs. Can't use it to torque them to the correct setting though.
        There is a special tool, 3122B, which is a skinny socket with an extension bar attached.
        [/partsdaddy]
        Ben
          Strange i found my deep sockets are fine for the job.
          • ian_jemo
            • Aug 2004
            • 284
            I went up Halfords and got a tool which allowed a torque wrench to be attached. And it had a magnetic end which pulled the plugs out. It was about 8 pound
            Ended up changing all the plugs. Got then from GSF for 44 pound which I thought wasn't to bad. Vagparts spark plugs are about 55 pound not sure if they are better plugs or not.
            Reading through a few threads regarding spark plugs it looks like the standard Bosch ones are the ones to go for. So thats what I did.
            • mcandmar
              • Apr 2004
              • 5118
              Beware of the plug sockets with the rubber ring to grab the plug, great in threory but once you fit the new plugs you cant get the damn socket out I ended up buying two and removed the rubber ring from one of them.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • Ski
                • 2591
                I use a halfords tool. they sell 2 different types, its the smaller one that fits for me.
                ABY Coupe
