Originally posted by Pisobiker
Have anyone tried to measure the actual lift and duration of the 7A cams? Everyone seems to take for granted that the quoted numbers in manuals are right, but are they
I've just fitted some 7A cams(nr. 054 xxx xxx) to my 2.5 and when checking cam data I was in for a surprise. The 7A intake cam isn't as agressive as people think. This is the measured data at 1mm lift:
Exhaust:
opens 45° before BDC; closes 7° before TDC; duration = 218°
Lift ~10.5mm
(Manual says 42° before BDC; closes 3° before TDC; duration = 219°. Looks like my cams are ~3° advanced. Not stock engine so.....
)Intake:
opens 4° AFTER TDC
; closes 35° after BDC; duration = 211°Lift ~9,6mm
(Manual says opens 6° BEFORE TDC; closes 38° after BDC; duration = 224°
)Is it possible that the 6° before TDC quoted for the 7A intake cam is a typing error and should actually be 6° after TDC? If so, it's like a NM-cam but 6° retarded.
Cheers,
Roger
