MTM RS2 375 00561 (fuelpresure problems??)
  • Jaap
    • Oct 2003
    • 258
    Still having problems whith this failure number.(00561)
    The car is doeing very wel, so a boost leak is not the problem.
    I did use a MTM 375 HP ECU but is the serie 3,7 bar fuelpressure regulator enough, or did MTM use a 4 bar??
    Do use now the SQ fuel pump and soon i need to change it for the 044.
    MAF en Lambda are new.
    Any help is welcome.
    Greetz Jaap
    Holland
  • Jaap
    • Oct 2003
    • 258
    Hmm
    nobody a idea
      its probably worth connecting to a vagcom to check it out next.
      • Jaap
        • Oct 2003
        • 258
        I did, and i gave me fault code 00561..
        Greetz Jaap
        • s2dude
          • Nov 2005
          • 1631
          Greetz Jaap
          What is the actual problem with the car?? Is it hesitant?? bad running or what?!
          00561 = Mixture Adaption limit not reached - Intermittent.
          I would suggest to do a full Pressure test with boost leak kit as a boost leak is MOST likely for this IMHO.....
          and post back more info so people can help!!!
          • Jaap
            • Oct 2003
            • 258
            Hmm
            I will test this, but now i am installaling a adapted AAN inlet manifold, so i need a little time.
            Greetz Jaap
            • Jaap
              • Oct 2003
              • 258
              Lmm
              Did read here on the forum that MTM also uses a SQ MAF in stead of a RS2 one.
              Can anyone confirm this??
              And did they use some other not stock parts (none RS2)??
              every help is welcome...
              Greetz from Holland
              Jaap
