Forge Dump Value Sound?
  • ian_jemo
    • Aug 2004
    • 284
    Hi all
    With the forge dump valve is it meant to give one big dump of pressure when letting of or not.
    On mine it gives a nice swooshing sound and lets off quite quietly is this correct.
    Don't get me wrong it does sound nice its just I was expected more of a release when letting off?
    Thanks
    Ian
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    i like the sound of the S1 sport quattro dump valve
    dump valve sound anything like that?
    • PeteRR
      • 1326
      A 'quiet woosh' sounds correct for a Forge Diverter Valve.
      A 'Dump Valve' will give a much louder 'Psshhh' sound as it vents to atmosphere.
      • s2dude
        • Nov 2005
        • 1631
        Originally posted by ian_jemo
        Hi all
        Thanks
        Ian
        a recirculating dump valve is quiet because it vents back to the inlet mani,....(the swoosh!)
        a dump valve that vents to atmosphere will make a load "psssst"...and waste boost IMHO also
        • Azman
          • Sep 2005
          • 3205
          My recirc valve is not that quiet but then I do have a cone filter too.
          Dark Grey Avant
          RS2 FARB
          Alloy Subframe Bushes
          • andrewd
            • Jun 2006
            • 278
            It's not su much "wasting boost", more the fact that a load of air already measured through the MAF sensor suddenly leaves the system, causing the car to temporarily overfuel.
            2005 Skoda Fabia vRS
            1993 100 S4 Saloon (resting)
            • ian_jemo
              • Aug 2004
              • 284
              So am I right in saying that the Forge DV makes a continous sound which increases with more revs and lets off a nice swooshing sound. Not like something you find on some boy racer car.
                no, it will only make a sound as you change gear/close the throttle.
                • phil2.016v
                  • Mar 2006
                  • 300
                  I replaced my Baily dump valve for a recirc, that gives a quiet swoosh and you get a chirp from the wastegate. Much better than the rs turbo pssshh!!
                  Audi 80 2.0
                  E21 BMW 316
                  Ibiza Cupra Sport
                  Mk3 Golf GTI colour Concept in black!
                  Mk3 Golf GTI
                  VW Caddy van with my gottis on it
                  • ian_jemo
                    • Aug 2004
                    • 284
                    Mine makes a sound all the time when the turbo is in.
                    Its the 006 Forge DV
                    Should it only make a sound when changing gear because mine is really quiet when changing gear
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      does the S1 use the same dump valve as the rest of the S2/RS2?could i buy a dump valve from audi intended for the sport quattro from somewhere?If not which is the closest recyrc dump valve that sound as the S1 valve?
                      I dont really like to hear any big noise,only subtle one
                      • s2avant
                        • 2426
                        Sport Quattro dump valve is different from all other models. Bizarrely you can't order one without full chassis number details.
                        Code:
                         Part number . : 035145710         RRP  . . . . : 36.43
                         Description . : CHASSVALVE        VAG stock  . : 0
                         Supply Notes
                         Text
                         Part must be ordered manually suppling full
                         chassis details to Audi PIC.
                         Parts Inv.
                         02.11.04
                                                            (Quattro sport)
                        You can order any other SportQuattro parts in the normal way. This is the only part I know of that has to be manually ordered. Are they really that special?
                        Has anyone seen/got one? or a chassis number so I can get a manual order raised
                        Ben
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          i have a video of a sport quattro doing some rounds off a track and it sounds AMAZING!!!i dont know the specs though and surely dont know if they can be used on our cars...
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            im interested if they do though!!!
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              found a cut off valve on ETKA with part number: 034 145 710 which is of the engine KW.It says it is only for this sport quattro model.
                              KW found that is the sport quattro with the 306hp
