I've just done the 1.8T coil mod on my S6 and the car is pulling very strong! Only problem is that the engine seems to cut off for a split second or so and the car does a nose dive. I'm getting engine speed sensor intermittent signal when VAG is plugged in.
This morning the VAG was plugged in while the engine was running, then the car just died and the codes were engine speed sensor and flywheel reference pin. I cleared the codes and started up the engine again.
Can anyone help me with this please...
