aan to 90cp wiring
  • s2 on the way
    • Jul 2004
    • 220
    aan to 90cp wiring
    does anyone have a pdf wiring diagram for a 93urs4 aan and a 90 cp by chance......
    I found service manuals on both on cd rom, but each is over 100 dollars, crazy.....
    gotta start splicing and don't want to just freestyle as that could end up pretty bad....
    my e mail is imaiami@aol.com if it needs to be sent thataway......
    thanks...
    dustin
  • LEE HIDSON
    • May 2006
    • 30
    Sorry mate, but if you do get the infomation i need it aswell for my aan fitted to sport project and if i get any info ill pass it on to you, thanx, Lee
    Audi Sport Project, rally Quattro Coupe, 100 Quattro estate, Viva GT
    • kwlw
      • Sep 2004
      • 1025
      • Country: Lithuania
      Why you need urs4 wiring diagram ? What do you expect to see there ? Wiring diagrams (at least VAG) are pretty complicated to understand if you are unfamiliar with such.
      I seriously don't understand why you need that, because from my expierence, engine loom separates from car so nicely (including fuses), you don't need anything to know about the car. One thing to remember, that diagnostic wires need to be unscrewed from fusebox before pulling the loom from the donor (it's not enough to disconnect all plugs).
      OK, if you don't like my post to yodasfro
      so here you are poor quality scans of original factory repair manual (I have it also in paper):
      Audi coupe wiring diagram is another story. I think you should try audifans or 20v.org for such info.
      Sau
      P.S. Have you visited:
      if some files are missing search them in different versions of the page:
      also try to search this forum.
      • s2 on the way
        • Jul 2004
        • 220
        werdems
        thanks sau.....
        I am just trying to get all the info that I can to make this go smoothly.....
        I haven't started the wiring since I dont' even have the car infront of me...
        i'll be getting it in a couple of weeks, all is ready except for the wiring, so I'm just trying to get as prepared as I can to make it go as quick and easy as possible....
        peace.
        dl
        • s2 on the way
          • Jul 2004
          • 220
          this is great,,,,,
          all the wiring diagram is in german, and I have a german wife....
          the wiring will be a bonding experience...woo hoo....
          car building for the family.......
          thanks again....
          hopefully I don't even need the diagram, but it couldn't hurt to have......
          and all the other info is much needed..
          I am sure I will be posting soon again once the process is under way and my mind is about to explode.......
          peace.
          dustin
          • kwlw
            • Sep 2004
            • 1025
            Slow down a bit and take it easy. If something you can always ask
            Sau
