I found an archived web page that seems to say it's simply a case of pulling the dash pod out, locating the pre-wired connector and popping a bulb into the correct location.
Pulled my dash pod out yesterday, and located what I think is the correct wire (tie-wrapped onto the bit of the loom that goes into the back of the oil pressure/temp/clock area). However, I couldn't work out where this should plug in, nor where the correct location for the 'check engine' light is?
Has anyone done this?
, only connector has empty place for contacts. I think virtually any car electric can "enable" it for you, especially if you keep things simple, and wire just LED into the corner of glove box
