Cylinder head - possible to fix?
  • Efini
    • 154
    • Home: United Kingdom Current: United States
    I have a ADU cylinder head with a hole between cylinder 1 and 2. The hole is alomst big enough to stick my little finger through. I think it was caused by a faulty head gasket.
    Is it possible to fix this in any way, will it be a recomended repair?
    Will try to post a picture of the head later.
  • zlobo
    • 967
    yes its fixeble, just need to heat upp the topp and weld the hole and then fix the surfice.
    ABT C5 Lord Of The Rings
    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
    kostic.nu
    • Efini
      • 154
      Sounds good, I would really like to reuse my old head as it looks in excellent condition except for the damage between the cylinders.
      Here's a couple of pictures (sorry about the size)
      • kwlw
        • Sep 2004
        • 1025
        • Country: Lithuania
        Yes, it's possible, our local head repair shop (quite advanced guys however) can do that, so I don't see the reason why yours cannot be fixed.
        Maybe it may turn cheaper to buy "new" one, like ex7A head from MRC. Especially because alloy is thin, and can be tricky in this specific head part. Make sure specialist does the welding and fills the hole with apropriate alloy.
        Sau
        • WabTheKing
          • May 2004
          • 2567
          i used these guys, top notch job
          • ~Delta
            • Apr 2005
            • 797
            Aye, most decent cylinder head specialists will be able to make a good repair to that.
            Good thing the Audi heads are not made of cast iron, quite difficult and expensive to repair.
            Never show a fool a half built house.
            Never underestimate the power of stupid people in large groups.
            Life is like a **** sandwich
            The more bread you have, the less **** you eat
