Fitting Std Recirc. valve in reverse?
  • S2 PTH
    • Dec 2005
    • 421
    • Home: Wales Current: United Kingdom
    Is this possible? Fitted a dumpvalve recently but due to its problems with idling etc I've decided against leaving it on for very long! Was wondering whether its possible or not to fit the standard bosch unit in reverese (vaccum/induction side pipes switched round) ???
    Or would I be far better getting an aftermarket recirc valve and doing that then?
    Ta
    _phil
    ...ever since I floored you I knew that I loved you!
  • fivepotnoodle
    • Jul 2006
    • 48
    Why?
    • S2 PTH
      • Dec 2005
      • 421
      Because I've been told that you can do it with Forge re-circ. valves and that it sounds better!
