hi people!
before i renovated my car i had one really annoying boost problem, what happened was is it would boost to a bar up to 4000rpm in any gear, then after the 4k mark it would cut back to 7psi (mechanical boost i think!) and from and after it had cut back, it would boost 7psi at whatever revs any gear untill i recycled the ignition or restarted the car. since then i have had the engine out to clean up, change steering rack and do some other stuff, however doing that i found 3 big pulley gueldges in the IC so ive changed that aswell, which i thought would be the problem! but to my dissapointment on saturday is wasnt!
. ive also changed the WGFV in that time aswell. now the car is back together and running the problem still exists, and i'm off to nurburg in a week and a half! (EEEEEK!), i'm now left clueless to what the problem could be and i cant read any codes off the ecu as the vag-com lead i bought diddnt seem to want to work! any one have any ideas? ive checked the barometric pressure sensor and got roughly the same readings as everyone else's that worked, but i don't see how resistance can tell that, was gunna check it on the oscilloscope but no-one else put there readings up, someone said about adjusting it to fool it but i could'nt find out how! as i have limited access to the internet! anyone have any ideas what could be wrong with my car! i'm willing to go to desperate measures to get it sorted and running sweetly before nurburg!
Thanx in advance
Steveo
. ive also changed the WGFV in that time aswell. now the car is back together and running the problem still exists, and i'm off to nurburg in a week and a half! (EEEEEK!), i'm now left clueless to what the problem could be and i cant read any codes off the ecu as the vag-com lead i bought diddnt seem to want to work! any one have any ideas? ive checked the barometric pressure sensor and got roughly the same readings as everyone else's that worked, but i don't see how resistance can tell that, was gunna check it on the oscilloscope but no-one else put there readings up, someone said about adjusting it to fool it but i could'nt find out how! as i have limited access to the internet! anyone have any ideas what could be wrong with my car! i'm willing to go to desperate measures to get it sorted and running sweetly before nurburg!Thanx in advance
Steveo
