Oil Temp Gauge
    Oil Temp Gauge
    How is the oil temp gauge wired up.
    Does it get its signal from ECU wiring or direct from oil pump?
    Mine started gettin a bit dicky today one min was working next min it wasnt. Looks like a loose connection but wasnt sure where to start.
    also how do u remove the temp gauge?
  • Mikes2
    • 1704
    Straight from sender to gauge - nothing at all to do with the ECU. It's probably gunk on the wiring as it gets quite messy
    Mike
    http://www.s2-audi.co.uk
      Ta,
      will take a look and give it a bit of a clean up, seems to be fine again today. tho :confused:
