UrS4 low boost problem ... SOLVED!
  • andrewd
    • Jun 2006
    • 278
    After nearly 3 months of owning my S4, I've finally cured the low-boost problem it's had since I acquired it by fitting a new wastegate frequency valve (WGFV)! (For reference, the AAN uses part number 034 906 283 H - I got mine from the very helpful vagparts.com for a good discount over the dealer price.)
    The symptoms I experienced were that from a cold start, the car would produce decent boost maybe once or twice, and then peg boost back to a purely wastegate controlled 1.4 bar. An ECU output test would happily cycle the WGFV, so it's quite obvious that the valve can still appear to work while not being able to control boost properly ...!
    It's been a really useful learning experience, and I now feel I've got a good understanding of "how things work" with the boost control system. For good measure I've also now fitted a new 710N (Audi S3) diverter valve.
    To say I'm blown away by the restored performance of the car is an understatement! Now I finally understand what all the S-Car fuss is about And to think it is costing me LESS to insure than my old Mk2 Golf GTI ...!
    Cheers for all the advice and info I've gained from the forum. Wouldn't have known where to start without you!
    Andrew
    2005 Skoda Fabia vRS
    1993 100 S4 Saloon (resting)
  • s2dude
    • Nov 2005
    • 1631
    Andrew
    Ahem.....just as I said ...Waste Gate Frequency Valve to replace first!
    • andrewd
      • Jun 2006
      • 278
      Very true I think I was just a bit thrown by the fact that it "seemed" to be operating okay during the output test, and the additional fact that everyone seemed to be pointing towards a boost leak.
      I owe you a beer!
      • s2dude
        • Nov 2005
        • 1631
        I owe you a beer!
        Keep the faith
          Just for the record - that Motronic output test just verifies that you have elecrical connectivity to the WGFV... It doesn't verify that its internal parts are in tact and capable of moving quickly enough to modulate boost control.
          Oh and the 1.4 bar that this AAN owner is talking about is ABSOLUTE pressure - as displayed on the UrS4/S6 digital boost guage. That is nominally 0.4bar boost of course - as controlled by the mechanical WG spring.
          Paul
          • andrewd
            • Jun 2006
            • 278
            Cheers for pointing the relative / absolute boost thing out. I don't reckon I'd have much grounds to moan if I was getting a true 1.4 bar of relative boost
