Im starting to run out of ideas on a S2 ABY where boost is completly absent. The engine runs fine under all conditions but the maximum boost that I come up to is approx 3psi; and this is with a (approx) 0.7bar spring in the wastegate...
Engine has a K26/27 and 3" dp+exhaust; custom exhm, custom i/c, 3bar map with other program+rs2 injectors, and now 7A cams.
The following have been checked/tried without any difference:
Fuel pump
Turbo
Wastegate in different configuration; even without controlhose ...
Stock ECU+injectors
Tried without exhaust; only running with dp
Pressure tested for leaks
MAF
new timing belt+changed to 7A cams.
TPS with tb
no errorcodes are noted
no exsessive black (fuel) smoke
no missfires
adjustable fuel pressure regulator
I unplugged the MAF connector and then i was able to get it to 4psi at one occasion before it hesitated like lack of fuel (with lots of throttle). If I remember correct; doesnt just the ECU run on emergency mode with MAF failing? it usually results in exsessive fuel consumption but it still runs fine (with 0.4bar boost).
So what is the obvious Ive missed ?
Fuel pump
Turbo
Stock ECU+injectors
MAF
TPS with tb
no missfires
